How to connect ThingWorx with external TCP Socket Server
Good morning
I've intercepted this thread because I think I have a quite similar need.
I have to interface a TWX instance with an external application (an AGV mission server) which accepts only TCP Socket connection (not WebSocket) and requires that the calling app implements a TCP Socket server too according to the attached picture (text is in Italian but it should be clear from the context), where the TWX server should act as the WMS (warehouse management system).
So the question is: is there a built-in way to instantiate a TCP Client/Server connection in ThingWorx? If not, how would you reccomend to proceed to address this case?
Many thanks,
Riccardo.
