How to connect and get data in mongoDB of MT-linki
  • December 16, 2021
  • 2 replies
  • 3681 views
Hi everyone.
I want to access fanuc's mongoDb and get data. Do you have a Solution or Example ?
Or can you tell me how to do it?
SH_KIM12-AmethystAuthor
Thank you for your reply,
Actually I'm an automation engineer, not a software engineer/developer, so I need a detailed solution or example that can be step by step .
best regard,
Hello @SH_KIM ,
Are you trying to  connect MTLinki, MTConnect and Mongo DB in the KEPServer?
Kindly respond your exact requirement.
Regards
Bhawna
Hi, bhawna
i'm trying to connect Thingworx and Fanuc's MT-linki.
That means It doesn't matter whether connect to mt-linki from TWX or mt-linki from kepware.
but I tried to connect using kepware. I don't think kepware support to MT-linki protocol. It seems to only support direct connection with the robot.
best regard,
Here is the article - "Connection to Fanuc MTLink with PTC Kepware products": https://www.ptc.com/en/support/article/CS339499
