Hi
Can anyone help me in regard to this subject with posted capture i attached ?
It would be appreciate if i get a reply from you.
Does this work if you hardcode the values that you are inserting
to be true/false or 0/1 ?
probably make that work first before going to the input parameters.
Hello PaiChung
Yes that has been worked since EMS created and tested.
Need more reply if you have idea for this post.
hello PaiChung
It works as attached photo when i clicked Input action but i don't know why.
You pointed the hardcord value are just type by myself ?
If so then how did you know ?
Not too sure, seems like it is at least picking up one value.
are you sure both input parameters have values assigned?
you could try to replace [[is_in_dock]] with just TRUE or FALSE (or 1 / 0)
and see what happens, this at least will confirm a value is written
if that is the case, then most likely you are not providing is_in_dock when the code runs
can it have to do with mapping?
