How to insert units in the value display
  • October 10, 2019
  • 2838 views
Hi there,
I am showing an information in the value display and this information is referent the weight where I use the unit "ton" (tonne). Like the image below:
To do it I used two value display, one to bind my value and other to write the unit (ton). Follow image below:
My question is: Is there any way to insert in the same value display the value and the unit? I have ever searched in the properties from value display and I did not find nothing about it.
Leonardo.
Best answer by zyuan1
You can use an Expression function, get your numeric input and the Unit together in one String, and then send the new result to the Value Display.
22-Sapphire I
October 10, 2019
I've always just used the label next to the value display.
You can always make the background and line transparent and then overlay that over a box so it looks like a single display.
einsfele1-VisitorAuthor
Hi @PaiChung
Thanks for your answer.
I do it too, but I would like to find some way to configure it in the same value display.
If I do not find other solution I will keep it.
That would be a solution if I had a single value display in a page. If I have to display multiple values of the same unit, for example, ten different kWh values, I would need to add ten different expressions.
Please correct me if I'm wrong,  Typically a mashup consists of multiple values, often of the same unit, to display.
