Initially posted in this topic
I am using s7-1200 plc , i want to write the plc tag value from thingworx to kepserver after that plc. It is a memory tag and boolean. from remote thing if manually i can set the value true/false, it is changing in kepserver, but through button widget not happening. How to update the tag value using button widget. Pls help me out
You can follow below articles,
Use SetPropertyValues() service of thing
