How to update the tag value using button widget.
Initially posted in this topic
I am using s7-1200 plc , i want to write the plc tag value from thingworx to kepserver after that plc. It is a memory tag and boolean. from remote thing if manually i can set the value true/false, it is changing in kepserver, but through button widget not happening. How to update the tag value using button widget. Pls help me out
