Import/Export
Sruthi
Import/Export
HI,
I am trying to export a project(entities+data) from my local instance to cloud ThingWorx(30 days trial version). I imported all the entities without data. Now I need to import the data. How to do that?
I upload the exported data file in a file repository and tried Import-> from file-> file repository-> but my file is not showing there.
mnarang
(To:Sruthi)
in that case, choose the export to file option for collection of entities and collection of data separately. while doing export for entities and data you can add Project/Tag in the option and that will export entity attached to the project or data attached to the project only.
4 REPLIES 4
tdixit
(To:Sruthi)
Hi @Sruthi
Thank you for reaching out to PTC.
Can you share a screenshot to see what is happening when you click on ImportSource as "fileRepository"
Also, have you checked the Help Center  to see how to perform import/export in ThingWorx
Toolika Dixit
mnarang
(To:Sruthi)
The best way to export (entites+data) is to export to ThingworxStorage option selecting the include data checkbox and Universal export checkbox. Once this export is completed you will get the exported folder(with date time stamp name) in ThingworxStorage/export directory. You can take out this folder and keep it on another thingworx ThingworxStorage/export folder and try to do import from ThingworxStorage and select the same folder.
Sruthi
(To:mnarang)
yeah, but if I do so the whole entities and data would be exported right?.
I want to export only particular project's entities and data.
mnarang
(To:Sruthi)
