Importing the Analytics Extension fails
  • May 16, 2017
  • 2 replies
  • 4446 views
I'm trying to import the Analytics Extension 7.4 into Thingworx 7.4 I get an error
mathcadconnector-extension:7.4.0Import Failed: Unable to update vocabulary [ TW ]: Vocabulary TW not found
The others appear to be imported but then when I proceed to the next step of the installation guide there is no Thing called TW_ML_Configuration
Not sure where to go from here.
Best answer by nsampat
Andrew,
I am confirming that this is a known issue with MS-SQL in conjunction with Analytics Extension.
Postgres will worked as an alternate DB when importing the Extension.
Neel
20-Turquoise
May 16, 2017
John GreinerNeel Sampat​ do you guys have any suggestions?
Thank you Polina Osipova for pinging us.
@AndrewJackson Can you confirm your ThingWorx Foundation installation version? Also, can you confirm what version of the Extension you downloaded? The error code you are experiencing leads me to believe you are trying to install Analytics Extension to an older version of ThingWorx Foundation.
There is a compatibility requirement for the installation which can be found here
You can find the download links here to obtain the correct version of Analytics Extension
ajackson1-VisitorAuthor
As I said  I have Thingworx Foundation 7.4.0-b159 and I'm installing ThingWorx-Analytics-7.4.0-Extension.zip
Ok, thanks for getting back to me.
