Industrial Connection can be created but not be deleted.
  • March 24, 2021
  • 4748 views
In my Thingworx composer, I created an industrial connection, then I tried deleting it but failed. "Unable to dispose thing" always show when I delete it.  I then found I can only create but can not delete industrial connection. I used Administrator account. I googled this question but found nothing can help. Hopefully here someone can help.
Best answer by slangley
Hi @eyli.
It appears that the issue was resolved by upgrading to 8.4.9.  The issue was not reproducible under the supported releases of 8.5 and 9.x.
If you agree that this was the solution, please mark this response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
Hi @eyli
Is the thing disconnected when you are trying to delete it?
Sachin
eyli14-AlexandriteAuthor
I just created a industrial connection without other settings. The I tried deleting it and failed with "Unable to dispose thing". May I know how I can know if it is connected or not?
It show "Now Active" when I put cursor on the connection icon. I also saw the isConnected property value is 0.
