Infotable Memory Usage
  • May 3, 2019
  • 2 replies
  • 2097 views
Is there a way to determine how much RAM an Infotable property is using? Preferably, a method that wouldn't involve setting the infotable, checking the total system memory usage, and then deleting the infotable and doing the subtraction.
Best answer by Tudor
Is this infotable invoked/fetched in a Mashup in any way? If so, browser Developer Tools should tell you the size of the data it retrieves as part of the response.
If we're looking at something *huge* (several GB), then a heap dump will come in handy for exact numbers.
22-Sapphire I
May 6, 2019
Hey Andrew, how about exporting that entity and importing on another instance (and checking memory before and after)
Tudor14-AlexandriteAnswer
agondek1-VisitorAuthor
Hey Tudor and Pai,
Thanks for your replies. I went ahead with the method Tudor proposed. It would be nice if you could get statistics on properties as granularly as you can get them for the services.
