Is it possible to call javascript service sync or async during runtime
  • August 2, 2020
  • 2 replies
  • 1492 views
A JavaScript service can be configured as sync or Async  during design time .    but is it possible to decide it during runtime ? that is , calling javascript service sync or async by passing into a indicator parameter .
Sean
Best answer by VladimirRosu_116627
Nope.
Do note that even if you use the async in the platform, you need to trust 100% your code will finish execution, because otherwise you might slowly end up with n async threads that kill your system.
That's one of the issues that are not visible that much when you use async: they spawn completely new threads which don't end up in a queue and are not controlled by any subsystem.
Hi @seanccc ,
have you ever figured out? I also would like to call a Service asynchronously which is not marked as such.
Thank you
Benny
Nope.
Got it, thank you very much for your immediate feedback.
