Issues importing ThingWorx Apps Manufacturing
RaulBernardo.PV
Wave ,
After configuring java I managed to enable an extension process only now I have a problem importing Thing worx - APPS -9.1.1-00 - extension-dependencies.zip.
I managed to do the whole process of enabling the PlatformSettings- Json or extension package by setting everything to true, and also importing the extension MED-61284-CD-091_SP1_Remote-Access-Extension-3-1-4.zip.
Only when you import this extension :ThingWorx-Apps-9.1.1-00-extension-dependencies.zip gives an error. It validates but doesn't matter
Translated by the Community Moderation using Google Translate
Olá ,
Após configurar o java consegui habilitar um processo da extensão só que agora estou com problema para importar o Thing worx - APPS -9.1.1-00 - extension-dependencies.zip.
Consegui fazer todo o processo de habilitar no  PlatformSettings- Json o pacote de extensão colocando tudo para verdadeiro , e também importar a extensão MED-61284-CD-091_SP1_Remote-Access-Extension-3-1-4.zip.
Somente quando vou importar está extensão :ThingWorx-Apps-9.1.1-00-extension-dependencies.zip dá erro .Ela valida mais não importa
What are the actual errors listed in the application log?
Hi @RaulBernardo.PV.
In addition to Pai's question, what version of ThingWorx are you running?  Were you performing an upgrade from an earlier release?
Regards.
--Sharon
I am using version 9.1
Translated by Community Moderation using Google Translate
eu estou usando  a versão 9.1
Hi @RaulBernardo.PV
Please advise whether you were performing an upgrade from earlier versions of ThingWorx and ThingWorx Manufacturing Apps and provide the ThingWorx logs for the time of the upgrade.
Regards.
--Sharon
