I have this problem where the LED label is blocked by the data.
View while setting up the mashup
Clicked on view mashup and the below is shown
Anyone is able to help me with the above? i was using 28px and font bold for the label.
Hello @newbie_here ,
You can adjust the Font size of the label in LED widget. Pls follow the given steps:
Kindly share if you have tried the abovementioned steps and these are working to resolve your issue.
Let me know if you are facing any challenge while implementing these steps or issue still persists.
Regards
Bhawna
