In Thingworx 9.0 , there is widget name like List Shuttle. what is the basic use case of this one and how to use it.
Hi @
Unfortunately, we don't yet have a lot of information available on this widget, but this information in the Help Center may be useful.
--Sharon
Hi @
--Sharon
Hi @Saranya_S.
Did you find the previous post helpful? If so, please mark it as the Accepted Solution for the benefit of others with the same question.
If it failed to answer your questions, please provide specifics and I will try to obtain answers.
--Sharon
Hi ,
Yeah i tired it.I have an requirement like an infotable has two columns which are Flag (boolean) and Asset name (String) to be binding in list shuttle widget. The list shuttle widget can automatically selected the Flag column which values are true in Source Side.
Hi @Saranya_S.
From your last post, were you advising that you were successful in using the list shuttle widget, or do you still have questions?
--Sharon
