8-Gravel
February 10, 2026
MQTT Connection to Broker Failing
  • February 10, 2026
  • 89 views
I am using ThingWorx version 9.3 with the MQTT Extension version 3.1. After configuring MQTT, the connection remains in a disconnected state, but it has been verified to be connected through a client tool.
Best answer by Surya_Tiwari
Hi @ST_10465152  Can you take a look at the article below and let us know your output?
https://www.ptc.com/en/support/article/CS398400
8-Gravel
February 12, 2026
Thank you so much, it worked! I was indeed using version 2.0 of the MQTT extension, and switching to version 3.1 still didn't resolve the issue. After reading the article, I cleaned the extensions in Tomcat, restarted ThingWorx, and reinstalled the MQTT extension, which finally fixed the problem
Hi @ST_10465152   kindly mark it as solution.
