Menu Widget default item is not selecting on mashup load
I am using ThingWorx 8.5.4-b222 in this tried adding menu entity with one item as Default true and passed this to Menu property of Menu widget in a mashup. But that item is not getting selected on mashup load.
Also, tried this using a data-driven menu for which created a service in which menu entries are added to infotable using MenuEntry datashape and set isDefault true for one menu item still the menu does not get selected on mashup load.
