Migrating all data and entities from one thingworx instance to another when thingworx not running.
  • September 12, 2019
  • 2456 views
we had a thingworx instance where a project been developed. that instance is not starting showing errors. error log file of thingworx application log as well as tomcat catline logs are attached with this post. please can we import all our project, and data from thingworx instance which is not running to another thingworx instance manually.
Best answer by slangley
Hi @mahesh.
From a review of your case, it appears your issue was resolved by the License Management team by extending the expiration date of your license.  If this is an accurate understanding, please mark this post as the Accepted Solution for the benefit of others on the community.
--Sharon
18-Opal
September 12, 2019
It looks like your license file has disappeared. If you fix it, then most probably your instance will fire up correctly.
2019-09-12 02:01:33.710+0530 [L: ERROR] [O: c.t.s.s.l.LicensingStateMachine] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to fetch license file with device id a4b0f1c6-d295-4ad9-9d3b-525f7dcbf8f5
2019-09-12 02:01:33.876+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to process capability response because Storage anchor break found.
2019-09-12 02:01:33.880+0530 [L: INFO] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to read trial license file. Attempting to load as Paid license
2019-09-12 02:01:33.926+0530 [L: ERROR] [O: E.c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] [message: Storage anchor break found.]
2019-09-12 02:01:33.926+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ====================================================================
2019-09-12 02:01:33.926+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] License file missing. It's expected at path : C:\ThingworxPlatform\license.bin
2019-09-12 02:01:33.927+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ====================================================================
2019-09-12 02:01:33.927+0530 [L: WARN] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Shutting down the Platform.
/ Constantine
Community Manager
September 12, 2019
Hi @mahesh.
Also, in the log snippet provided by Constantine, is this error:
This could indicate corruption in the trusted storage.  If that is the case, we will most likely need to create a case for this issue in order to schedule a WebEx for troubleshooting the issue.
Do you currently have a license file located in \ThingworxPlatform?  Even though the log indicates the file name is license.bin, it should actually be license_capability_response.bin if you are running ThingWorx 8.1 or above.
Please provide a screenshot of the contents of the \ThingworxPlatform folder so we can determine how best to proceed.
--Sharon
mahesh1-VisitorAuthor
we have also tried by put the license file with name license_capability_response.bin but it ignored the license and gives the same error. the license file get renamed to ignored_license_capability_response.bin.
