Migration from Thingworx MSSQL 8.5.1 to Thingworx AZure SQL 8.5.1(single instance)
  • February 2, 2021
  • 1980 views
Can you provide the steps how to migrate the existing Thingworx version 8.5.1 MSSQL to Thingworx version 8.5.1 Azure SQL(single instance)?
Thanks&Regards,
Latha
Best answer by vi1
Hello Om,
Thank you for response.
As mentioned in document , we have to go with Azure SQL Managed instance to upgrade from MSSQL to AZure SQL. But We have selected Azure SQL single instance option so we will go with general thingworx migration process like import the existing entries and data after connecting to Azure SQL.
Latha
Hello @vi1
Please refer the following communtiy post. For your answer please check point no 8 in the post
https://community.ptc.com/t5/IoT-Tech-Tips/10-FAQs-on-ThingWorx-with-Azure-SQL/m-p/619921
Please let me know in case it doesn't resolve your query.
Om Dukiya
vi116-PearlAuthorAnswer
Hello Om,
Latha
vi116-PearlAuthor
Hello Om,
Migrated from Thingworx 8.5.1 MSSQL to Thingworx 8.5.1 Azure SQL successfully. Observed License file name is "ignored_license_capability_response" but License subsystem is showing that License expires in 726days. Imported all the entities and data into thingworx successfully. Do we need to generate the license key again?
I have opened support case: 15742125
Latha
