Modifying the data shape in Production
HI Team,
we have a scenario where we need to modify the fields of data shape which is used in data table again which holds like 10000 records. we have done a quick test and found out the following behaviors.
I have added around 100 entries to a data table.
Case 1 : Existing Field was Deleted from data shape
Behavior : Then also Remaining field values were available.
Case 2 : Deleted field was added again to data shape
Behavior : Respective field values were showing up again
Case 3 : Added a new field to data shape
Behavior : it was empty and the field does not have any default values. It was undefined.
Note: It is not possible to rename the existing field of a data shape. Need to be delete it and create with new name.
Details:
Thingworx : 7.1.0 Neo4j version
Tomcat : 8.0.38
Just wanted to confirm, If it is safe to modify the fields of a data shape where its data table holds thousands of records.
Please let me know if there are any additional things that needs to be take care in this case.
