Navigation between tabs (link, button, etc)
Good afternoon,
Is there any widget that allows me to navigate between tabs without using Tabs Bar?
Let's visualize this with an example:
In my Tabs Bar I have 3 tabs: plant layout, welding stage and coating stage. I can switch between tabs using the tabs bar but I would also like to be able to click in the different parts of the layout and navigate to the specific manufacturing stage.
As you can see, I am searching for a widget similar to the Navigation Button but for tabs, not for mashups.
Thank you very much, Rodrigo.
