I am trying to install twx flow 9.3 but it is failing with 502 Gateway errors. Any help would be appreciated.
Hello @AM_10639709,
pls refer the following article explaining the error 502 Gateway:
https://www.ptc.com/en/support/article/cs339610?
Let me know if you are still facing the same issue.
Regards
Bhawna
Hello @AM_10639709,
Regards
Bhawna
Hello @bchaudhary
Issue resolved after making changes in Vhost-flow config file. Thanks for your help.
