On project import the users passwords does not work
  • July 24, 2024
  • 4037 views
Hello community,
I have very strange issue when i import the project on for eg another server the users which are already there and get also imported on this project do not able to login with their passwords. Then i set the passwords again and everything works then for eg again after some time when i do import project with users the users passwords got disable and again i have to do this process.
I think i should not import users which are already present on the server..
Hi @MA8731174
Can you share the logs here, which type of error look at the logs, I want to know.
MA873117416-PearlAuthor
Hi @Surya_Tiwari  i could not see the logs at that time but when i update the password only then it starts working. I think the password get expired once you import the users. The users would be definitely there in platform but with expired password.
Hi @MA8731174  You have imported entity and data both or only entities?
