Pass Parameters from Master to Children
i have a Master Mashup and want to pass parameters to the Mashup which is using my Master.
So i set the State in my Master to, for example "Running", then my Mashup should update content accordingly. I just need the value i set on my Master Mashup somehow in the other Mashups that are using it.
Is this possibly via Mashup Properties? Or how can i do this?
Url Params came to my mind, but arent the best solution, because it is just a filter.
Cheers Pat
