I went through you log and found this error:
"Error running .\DescriptiveAnalytics-4.5.7-SNAPSHOT-windows-installer.exe"
I believe that there may be an issue with the installer that you originally downloaded since there is the word snapshot in the file name. Could you try downloading ThingWorx Analytics server 8.3 again and see if this resolves the issue.
Also make sure to remove the failed installation by using the uninstallation script before installing the new one.
John
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
