Project package does not include all the entities in the project
  • October 31, 2023
  • 1538 views
All environments mentioned :  ThingWorx 9.1.14-b1128
In a development environment i am trying to package a project where I have all entities being DataShapes for then import the solution in the production environments.
Nevertheless, the package seems to not include all entities though in production cannot update as it seems to be deleting already existing and in use DataShapes.
Came across some cases resolution to restart the environments, package and import again, restore possible missing files, but nothing worked.
Even in production after importing the package solution, checking the repository i do see the mentioned DataShapes in the error are indeed not present when downloading the .zip file.
22-Sapphire I
October 31, 2023
Is it at all possible that those DataShapes are coming from some imported extension that may not have been imported on your production environment?
DUlinic5-Regular MemberAuthor
No, the dashapes are from the same extension imported already in production.
Is just they are not packed to solution central from the development environment for some reason.
Therefore in production when i deploy seems like i am trying to delete them, but it is mainly because when it looks for it, in the package they are not there.
22-Sapphire I
November 9, 2023
I vaguely remember someone else having a similar issue, I would start a support ticket for this.
