REST api returns Http 400 Error code
dnaik
I was trying to call REST api of a external system  through Thingworx using function postJson(..) method. But It returns http status 400.
But same api works well in Postman. Any suggestion ?
Note: In both the channel(i.e. postman and Thingworx) REST header is being set correctly and REST URL is being used as exactly same.
supandey
(To:dnaik)
Hi Debiprasad, could you please share your REST call? In the meantime, just wanted to check if you have had the chance to look at the on ThingWorx REST Design
ankigupta
(To:dnaik)
Hi Debiprasad Naik​,
Try switching on Allow Request Method Switch in the platform Subsystem configuration.
ankigupta
(To:dnaik)
Cat
(To:dnaik)
    I have attached screenshots for your reference.
    1. json in Body
    2.  Content-Type & appKey in Header
