SSO via REST
MF_10410533
SSO via REST
Hi all,
is it possible to access the SSO (Single sign on) configuration via REST?
Thanks in advance.
nmutter
(To:MF_10410533)
You can reach configuration via standard TWX REST API. To get configuration you will call services like GetConfigurationTable or SetConfigurationTable on the entity "<host>/Thingworx/Authenticators/ThingworxSSOAuthenticator".
To authenticate you will need to have an AppKey with needed permissions (or if SSO is NOT enabled via BasicAuth).
2 REPLIES 2
nmutter
(To:MF_10410533)
