SelectedRowsChangedCallback is broken in 9.3.4
JU_10321794
8-Gravel
SelectedRowsChangedCallback is broken in 9.3.4. already opened a case with support.
1 ACCEPTED SOLUTION
Reply from support:
Thanks for your email.
I checked with R&D and this cannot be implemented in 9.3.5 as this a code fix and code submissions for 9.3.5 are already closed.
Also, I checked with the team about workaround, and currently there is no workaround available for this issue.
The expected release date of 9.3.6 is Dec 2022 (date could change).
Hi @JU_10321794
As the alternative you could try to use Grid Advance widget which now is already in the legacy widget, but still working
Hi @danmorin
I know, but sorting a column is a requirement. i will properly make a workaround, SelectedRowsChanged triggers multiple times on initial load.
Just posted it on the form so google finds this if someone cant figure out why it ain't working.
i will await the reply of support. before creating a workaround.
Thanks for the advice anyway, it will help someone else.
Reply from support:
