Smart Property Widget
  • March 16, 2017
  • 3334 views
I am trying to use smart property widget for displaying a fields which are dynamic. The display is coming inconsistent when GridMetaData JSON is fed through a service.
Wondering if anyone has used this widget from market place.
thanks,
Preeti
    Hi Preeti,
    Please tell us what's the Extension name that you download from the MarketPlace?
    Lily
    Hi Lily,
    It is Smart Grid Property Widget from Thingworx lab.
    thanks.
    Yes. It is very inconsistent. Looks like the DOM in Thingworx is varying with every refresh.
    I also tried with static JSON for GridMetaData and it worked. However JSON is dynamic for my use case so I could not use smart property widget.
    For now what I did is to use two Dynamic Property widget where I am dynamically populating fields based on the grouping. I do not like this way. Since the UI does not look good.
    If you find a fix for this that would be great. I probably have to look into how to modify this Smart Grid for my use case.
    thanks for looking into this. I appreciate it.
    Preeti
