What is the use of new sprites widget. Is there any video available regarding this?
Anupriya Agarwal - There is only a user guide available at this point of time which you can refer from below URL
The Sprites Extension allows you to incorporate sprites (pictorial animations) into a ThingWorx Mashup. The extension enhances ThingWorx with the addition of a Sprites widget, which appears in the mashup builder after importing the extension. Sprite animations created with the extension can be fully customized for size, speed, and dynamic activation.
Anupriya,
Any update on this? Were any of the posts in the discussion helpful? If so, could you click on the "correct answer" or "mark as helpful" button and let us know?
