Stack Tracing still active after disabling
  • April 28, 2025
  • 1755 views
Hi, i'm using ThingWorx 9.3.9-b1648, and I'm seeing a lost of logs related to the Stack Tracing feature.
Even after disabling it, the system still generates these logs.
Has anyone else experienced this issue?
Best answer by VladimirRosu_116627
Incorrect 🙂
That setting applies for the log writing activity, it does not affect only the UI.
With WARN active, the application log should not increase dramatically. However. please check that the same is valid for the other logs as well.
I'm curious to hear the outcome.
Hi @AlessandroN  Have you disabled it from LoggingSubsystem > Configuration > Enable Stack Tracing?
Can you share your logs?
Sorry @Surya_Tiwari but my answer seems to have been deleted.
Anyway, yes I've already tried to disable it from the LogginSubsystem but it still logging.
Which logs do you need? Because the Application Logs are just full of tracing (no sense tracing for me imho)
Hi @AlessandroN
1. Is the ThingWorx instance having a normal CPU usage?
2. As @Surya_Tiwari  asked, it would be good to share the specific log lines, as you mentioned that you see a lot of  logs related to the Stack Tracing feature and we're unclear what exactly is the message (for example I never say in the Application Log a message that complained to the "Stack Tracing" feature itself, but I saw some message that contain the stack traces themselves, as below.)
3. Are those stack traces something that belong to ThingWorx features, or do they belong to a third party extension ? (I'm saying this because in a third party extension you could just decide to put the whole stack trace in the Application Log.)
