Stack Tracing still active after disabling
  • April 28, 2025
  • 1755 views
Hi, i'm using ThingWorx 9.3.9-b1648, and I'm seeing a lost of logs related to the Stack Tracing feature.
Even after disabling it, the system still generates these logs.
Has anyone else experienced this issue?
Best answer by VladimirRosu_116627
Incorrect 🙂
That setting applies for the log writing activity, it does not affect only the UI.
With WARN active, the application log should not increase dramatically. However. please check that the same is valid for the other logs as well.
I'm curious to hear the outcome.
Hi @AlessandroN  Have you disabled it from LoggingSubsystem > Configuration > Enable Stack Tracing?
Can you share your logs?
Hi @Surya_Tiwari , yes I tried to disable it several times, but unsuccessfully.
I paste here an extract of Application Logs, because are just full of these kind of lines:
 are no subscribers to publisher Connectable
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-8] There are no subscribers to publisher RemoteThing
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-8] There are no subscribers to publisher GenericThing
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-8] There are no subscribers to publisher RemoteThingWithTunnelsAndFileTransfer
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-8] There are no subscribers to publisher Reportable
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.w.c.ThreadLocalContext] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-8] ----> CURRENT security context [user: Administrator, depth: 1]
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-8] Firing AnyDataChange on Thing: Stazione_Programmazione_L16_4
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-12] There are no subscribers to publisher Stazione_Programmazione_L12_3
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-12] There are no subscribers to publisher RemoteThing
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-12] There are no subscribers to publisher GenericThing
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-12] There are no subscribers to publisher RemoteThingWithTunnelsAndFileTransfer
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-12] There are no subscribers to publisher Reportable
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.w.c.ThreadLocalContext] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-1] ----> CURRENT security context [user: Administrator, depth: 1]
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.s.s.i.SubscriptionStore] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-16] There are no subscribers to publisher GenericThing
2025-04-28 13:40:12.813+0200 [L: TRACE] [O: c.t.w.c.ThreadLocalContext] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-14] ----> CURRENT security context [user: Administrator, depth: 1]
2025-04-28 13:40:12.813+0200 [L: DEBUG] [O: c.t.t.c.RemoteThing] [I: ] [U: Administrator] [S: ] [P: ] [T: TWEventProcessor-14] Performing property read from CACHE: [name = isConnected, value = false]
