Store a if/else expression inside a property or a table
  • June 18, 2020
  • 3145 views
I have a quick query to be asked, I am creating a condition statement or a if/else condition dynamically and this statement is being stored in a property for testing purpose. I wanted to know how to use the expression stored inside the property for the if/else conditions because if I use the property directly it is evaluating if there is a value in the property and returning always true. But I want the condition inside the property to be evaluated.
Is there any solution for this purpose to use the dynamically created expressions as it is required?
Thanks in advance
With Regards,
Srijith
Best answer by rjanardan
I do not know if this fits your requirement or whether this is the best alternative. I am assuming left operand is always one of the properties of the thing. Please test properly.
var exp = "me.prop < 10" ;
var operation = exp.split(" ");
var propValue = me[operation[0].split(".")[1]];
var result = false;
if(operation[1] == "<" && propValue < operation[2]){ // inlcude other operators using ||
 result = true;
eval() would have worked but its usage should be avoided. Never use eval()
I can use eval() as a solution but as it is mentioned to reduce the use of eval() is there any other way I can solve the same issue other than eval().
'Splitting the string into operands and operators and then looping over all operators, is an option.'
Can you make this option a bit more clear? You mean that for eg I have a condition say :
var result;
if(exp)
    result = "Success";
else
   result = "Unsuccessful";
Let's consider this example
while using eval() I can do like :
var result;
if(eval(exp))
    result = "Success";
else
Can you explain the tedious one just to make sure if I am right with I got from you? And if I can ensure that the string being passed to it cannot be modified to contain any malicious code which is better to use, the long way or this
