Storing data pulled from a database inside a stream/value stream
I was wondering weither it would be possible to store the data i pull from my DB inside a stream?
I succefuly made the connexion to Mssql and i am able to query those data using a service.
The reason behind this is that i'd like to be able to iterate through or use the recent temperature data stored in the stream inside a subscription that does some manipulations for me.
Thank you in advance
