[Subscription] Enable Subscription
Hi guys,
I try to deploy an application which display the information from a weather station. Currently, I access the data via an API using token & credentials. I have three services, one for get access token, one for have new token with a refresh token and one other to access the data. I need to launch the services at specifics timeloop.
So I create a subscription to Thingstart event to launch my first service. I also create two others subscriptions which bind two differents timers to launch my services, they are basically disable.
I want to add at my first subscription (Thingstart event) an enable subscription method to enable my other service when I launch my thing. Badly it don't recognize it :
"Error processing local event: Execution error in service script [QAI_netatmoConnector ThingStart] : ReferenceError: "QAI_Timer30S" not recognize (ThingStart#5)"
this is my first subscription:
// result: JSON
var result = me.GetAccessToken();
var params = {
propertyName: QAI_Timer30S /* STRING */,
thingName: undefined /* THINGNAME */,
eventName: Timer /* STRING */
me.EnableSubscription(params);
any idea ?
Guillaume
