TWX 8.5 Data Shape for SelectedItems in Dropdown Widget
  • March 22, 2021
  • 963 views
What is the data shape for the selected Items and for standard widgets like this that accept infotables where is the best place to find documentation on what data shapes to use with them when generating data?
Best answer by kazunari
For example, create a same property(Infotable). Create it with the same data shape which you are using on Dropdown Widget "All Data". Set a value which you need to be selected on composer. Then bind the property to Dropdown widget(Selected Items).
kazunari12-AmethystAnswer
