Theme Integration
  • December 27, 2021
  • 1512 views
How to integrate the theme in the mashup? how can we integrate custom html?
Best answer by bchaudhary_448008
Hi @VS_10112707 ,
Thank you for elaborating the query!
 To achieve that, you can create a Master Mashup including the header, footers and layout of your choice. Then after, this designed Master Mashup can be  attached to any mashup where you are planning to use the defined design.
Pls feel free to revert back if you still face any further challenges.
Hello @VS_10112707 ,
I am unable to understand the given query. Are you referring to use Custom CSS  by  mentioning integrating theme in the Mashup?
Kindly check the given article if you are looking for custom CSS:
https://www.ptc.com/en/support/article/CS332429
Revert back if anything is unclear.
Regards
Bhawna
@bchaudhary_448008 i would like to integrate theme in thingworx mashup. i want set some header ,footer and grid layouts so we can integrate that theme in other mashup screen. that type of functionality i needed.
example like i have multiple html pages i want to convert them in mashup screen so fix header ,footer,menu and body part
let me know if you are still not getting
Hi @VS_10112707 ,
