ThingWorx 8.4.5- Adding/Deleting grid rows within mashup
  • September 9, 2022
  • 2 replies
  • 2610 views
I have a mashup with an advanced grid that displays data coming from sql server database. I want to be able to add and remove rows in order to add or delete row data. I was able to add two two advanced grids. Grid one showed all my data and grid two was empty. I was only able to select multiple rows by holding ctrl button. That's the only way I could pass data to the other advanced grid. Is there another way of doing this? I want a user within the mashup to be able to add/delete rows.
Rocko
Multi-selecting rows using CTRL is the standard way of multi-selecting, why would you want another way?
It is unclear, what the real question is.
Also, please note that your version of Thingworx is out of support for almost a year. You might want to use a current version.
you can use the "List Shuttle Widget" to select items from an existing list, the source, and place them on a new list, the target.
c.f. https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/ListShuttleWidgetThemable.html
However, you can move an element to the destination list only once. Otherwise you have to create a workaround with 2 grids.
Best regards
Marc
There doesn't seem to be a List Shuttle Widget in the version of ThingWorx I am using(8.4.5).
But this widget would seem to resolve the issue of selecting from a source and placing on a new list (the target).
Is there something like the "List Shuttle Widget" in this version I am using?
Yes, I read that in the documentation. Tried to look through all the widgets in the panel but the list shuttle was not one of them. I did see other posts where it mentions the list shuttle being in version 9.
Best
