ThingWorx Metrics Reporting Services
  • November 29, 2016
  • 1766 views
Hi all.
In order to activate the “ThingWorx Metrics Reporting Services”
·        I select the “PlatformSubsystem” element in Thingworx Composer
·        I checked the “Enable Metrics reporting” check box
·        I compiled the “PTC username” field
·        By using “Change Password” button, I introduced my PTC password
When I push the “Request” button, I receive this error message.
My Thingworx server is implemented on a Linux Ubuntu 14.04 LTS Virtual Machine in Microsoft Azure cloud.
Should I to activate some Inbound or Outbound rules in firewall?
It is necessary to install the Thingworx Connection Server?
Thank you.
Best regards,
                  Sergio
Hi Sergio Marino​,
Could you try running StartMetricsCollectionService service in the platform service to see if it helps.
Ankit Gupta
smarino1-VisitorAuthor
Hi Ankit Gupta.
I tried to start the StartMetricsCollectionService service. The result of this operation was positive.
However, when I try to activate the “ThingWorx Metrics Reporting Services”, there is the same error.
Thank you.
Best regards,
   Sergio
