Thingworx Flow Connector OAuth Authorization
  • May 2, 2020
  • 2194 views
I want to use connectors like Gmail/Office365 in Thingworx Flow. I am following with the article  to create Oauth authorization.
After I created the OAuth configuration JSON file, I need services to upload it to the ThingWorx Flow server. The article indicates that there three services (LoadOAuthConfiguration/DeleteOAuthConfiguration/GetOAuthConfiguration) that can be utilized, but I can't find them under Composer/System/Subsystems/WorkflowSubsystem/Services, could somebody tell me why? The Thingworx version is 8.5
Hi @TongChen
Per mentioned here , is your ThingWorx Flow server running? and you are logged in to ThingWorx as Administrator?
Vibhuti
TongChen1-VisitorAuthor
Both are exactly yes.
Community Manager
May 8, 2020
Hi @TongChen.
Are you running ThingWorx 8.5.0?  if so, it's recommended that you upgrade to one of the patch releases due to a number of improvements and bug fixes.
I just check on ThingWorx 8.5.5, and I see the services you mentioned in your initial post:
--Sharon
