I want to use connectors like Gmail/Office365 in Thingworx Flow. I am following with the article to create Oauth authorization.
After I created the OAuth configuration JSON file, I need services to upload it to the ThingWorx Flow server. The article indicates that there three services (LoadOAuthConfiguration/DeleteOAuthConfiguration/GetOAuthConfiguration) that can be utilized, but I can't find them under Composer/System/Subsystems/WorkflowSubsystem/Services, could somebody tell me why? The Thingworx version is 8.5
Both are exactly yes.
Hi @TongChen.
Are you running ThingWorx 8.5.0? if so, it's recommended that you upgrade to one of the patch releases due to a number of improvements and bug fixes.
I just check on ThingWorx 8.5.5, and I see the services you mentioned in your initial post:
Regards.
--Sharon
Hi @TongChen.
Were you able to resolve your issue by upgrading? If so, please mark the previous response as the Accepted Solution for the benefit of others on the community.
If you are still having issues, please let us know the status so we can assist.
Regards.
--Sharon
