Thingworx as a Client- REST API
  • February 25, 2022
  • 1278 views
Hi All,
Hope to get some guidance, as i am new to REST API in thingworx
I hope to know the plausibility:
  1.  A bit from the field trigger an alarm,  this bit is a properties of Thing:MonitorER.
  2. When this bit trigger, ThingWorx will Post/Put some data to trigger an remote REST API server.
Is there any tutorial related to creating a Services in Thingworx or in Thing (eg:Thing:MonitorER ?) to Put/Post data to Remote REST API server with the bit is trigger?
I read the Postman as Client to request Thingworx info, ThingWorx REST API Cheat Sheet and CS224211. I am abit lost.
So i hope know if there is any tutorial or guide specifically on how to create services for POST data from Thingworx to Remote REST API server, any online training i can look into.
hope someone can provide some info, i would like to learn more.
Thank you in advance.
Best regards
NewbieKek
Best answer by PaiChung
ThingWorx has a resource called 'Contentloader functions' in there are all the GET/POST/PUT services that you can use with an external REST API
Aside from that if you need guidance on how to create services etc, I recommend PTCU where you can take the intro level classes for ThingWorx developers.
PaiChung22-Sapphire IAnswer
22-Sapphire I
February 25, 2022
