Hi all
I have do thingworx platform installation as per PTC guide.
I do Tomcat installation time paste this section in java area.
-Dserver -Dd64
-XX:+UseG1GC
-Dfile.encoding=UTF-8
-Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx\WEB-INF\extensions.
After that restart tomcat. tomcat server stopped and error 4 occured.
Next step i cannot do this.pls consider me and reply me sir....
Hi @veerasekar.
There could be a number of things wrong. From the settings you provided, please make sure that the period (.) does not actually exist at the end of this setting:
If it does exist, remove it and restart Tomcat. If the service still fails to start, please provide the logs located at C:\Program Files\Apache Software Foundation\Tomcat 8.5\logs. Also, please provide the platform-settings.json located in the ThingworxPlatform folder.
--Sharon
Hi @veerasekar.
--Sharon
Hi @veerasekar.
Did my last response help you to find a solution? If so, please mark it as the Accepted Solution for the benefit of others with the same issue. If you are still encountering issues, please provide the logs and further details of the problem.
--Sharon
