Thread error HTTP Status 500
  • September 17, 2017
  • 2 replies
  • 5949 views
Hi, all.
I can't suddenly connect to the server.
I don't know why. This error occurs.
ApplicationLog
Actually, connection was smooth until just a few days ago.
Ubuntu 14.04, Tomcat8, Postgresql9.4..
Please help me T.T
Hi Jeongeun, just to confirm is PostgerSQL DB is up and running? Are you able to connect to it via PgAdminII client? Can you also share the tomcat logs?
jkim-611-VisitorAuthor
yes, running.
What does mean this error? I deleted everything. And I installed Thingworx8. However, the same error occurs.
help me.
Is it possible for you attach the applicationLog and Tomcat's catalina log here? It's bit hard to check for issues just with snippets of logs.
20-Turquoise
September 18, 2017
How do you deploy your application? Do you drop the .war file in Tomcat/webapps folder or upload via the browser? The browser/UI method would not work and likely  cause this error.
JUdging by the logs your database isn't connecting either.
I copied .war file under the webapps folder..
Thank you for your reply. I fully removed and reinstalled it.
Each time I run pgadmin3, the following problems occur in the database. I'll need to reenter password. Is right?
