Tomcat fails when Thingworx webapp installed
  • July 24, 2017
  • 5170 views
I'm following the guide for RHEL.  I installed Tomcat 8.5.16 since I couldn't find the noted version.  Tomcat works fine and can be accessed at localhost:8080.  As soon as I add the Thingworx webapp it can no longer be accessed.  Interestingly, if I remove Thingworx.war and the xploded folder while tomcat is still running it I will be able to access the Tomcat welcome page again.  No need to restart.
Hi Anthony, could you check the error in the tomcat log when you are attempting to deploy the ThingWorx war? Which version of ThingWorx are you attempting to install and with which persistence provider?
amandra1-VisitorAuthor
I tried the 8.0 trial and I get a login screen, but it doesn't load.  So the initial problem is probably related to the combination of tomcat and thingworx.
