Tree Grid Advanced 4.2.0 Row Selection does not work when isEditable property is Checked
Tree Grid Advanced 4.2.0 Row Selection does not work when isEditable property is Checked.
Steps to reproduce:
- Add Tree Grid Advanced widget (4.2.0) on your mashup
- Bind any data to it ( to be shown as in Tree structure)
- Check "isEditable" property in Widget's property window
- Now bind SelectedRows to any service
- Set property "RowSelection" to single/multiple
Now, when you view your mashup, when data is displayed in Tree format. You can't select any row that means your SelectedRows and SelectedRowChanged are of no use.
And when isEditable property is unchecked, it allows you to select any row in the Grid.
This is working fine with Tree Grid Advanced 3.0.6, but not with 4.2.0.
