Unable to disable Vertical Scrollbar for the collection Widget in a mashup
Giri
I'm having the similar issue - the Collection widget scroll bar. Do let me know if you found a resolution or workaround for this issue.
3 REPLIES 3
bchaudhary
(To:Giri)
Hello @Giri ,
Pls share the ThingWorx version you are on currently.
Bhawna
Giri
(To:bchaudhary)
I'm using Thingworx 9.3.9
Tone
(To:Giri)
Hi @Giri ,
a workaround could be to disable the scrollbars with the following CSS and the custom class "noScrollbars" for the collection:
/*Custom CSS*/
.noScrollbars ::-webkit-scrollbar {
display: none;
