Unable to install Thingworx using Thingworx ARM Template in Azure
  • August 3, 2021
  • 1641 views
Hi All,
I am trying to install Thingworx 9.0 in Azure using Thingworx ARM Template but I am facing an error message while installing Thingworx using ARM Template. PFB the error message from Azure while Validating  the template.
Deployment template validation failed: 'The value for the template parameter 'twxadminPasswordOrKey' at line '292' and column '30' is not provided.
Please help me in resolving the issue. If there is any document available. Please let me know
Best answer by bchaudhary_448008
Hi @koushal ,
Please refer the help centre document for your reference
Azure thigworx installation
Do let me know if you need further help.
regards
Bhawna
Hi @koushal ,
regards
Bhawna
Sorry, but the issue is still present in the current ThingWorx ARM template. The provided reference does not help to resolve the issue.
Community Manager
March 2, 2023
Yes, unfortunately. Our R&D team has acknowledged that the template is not working. It was designed for a special project and has not been maintained since then. There are some on-going discussions regarding the future of the template.
For now, you’ll have to use another method.
--Sharon
