Update DT using service
  • June 29, 2021
  • 2 replies
  • 5098 views
I have a datatable having fielddefinitions of datatype infotable(5 rows & 5 columns). I want to update those infotables fielddefinitions using script. I am trying to pass values in a query of UpdateDataTableEntriesWithQuery. But its not working!!
Best answer by AP_9587236
I used this logic inside for loop, the custom datas are successfully updating inside Datatable. Thanks for your help.
updateValues = Things[DataTableName].GetDataTableEntries();
updateValues[i].Details[0].Name = Name1;
updateValues[i].Details[1].Name = Name2;
updateValues[i].Details[2].Name = Name3;
updateValues[i].Details[3].Name = Name4;
updateValues[i].Details[4].Name = Name5;
updateValues[i].Details[5].Name = Name6;// INFOTABLE
var params1 = {
tags : undefined,
source : undefined,
values : updateValues,
// UpdateDataTableEntries(tags:TAGS, source:STRING("me.name"), values:INFOTABLE(DTName), location:LOCATION):STRING
Things[DataTableName].UpdateDataTableEntries(params1);
22-Sapphire I
June 29, 2021
What exactly are you trying to do?
UpdateDataTableEntriesWithQuery would update matching rows in your table. (runtime operation)
but you say you want to update infotable field definitions which is a design time operation.
Yes, the description is misleading.
Are you trying to update the DataShape of your Datatable, or update the value of this DT?
The infotable you mentioned is for your whole DT value entry, or a specific column which is an infotable typed property?
Exactly, The datatable having specific columns which is an infotable typed property? I want to update that column (having infotable datatype) through script(by getting datas from user).
AP_958723617-PeridotAuthorAnswer
var params1 = {
tags : undefined,
source : undefined,
