I have contained mashup in which i have label widget binded to the mashup. During the initial load of the containing mashup the values from kepware tag are not displayed. but if the value from kepware is changed after load, the values are updated on the label widget.
Is this a known issue or some bug that i need to fix?
Are you using any custom services to pull data from Things to Mashup?
Ensure those service should execute Mashup "Loaded" (mashup on load) event.
Hi, I am not using any custom service to pull the data. The widgets are directly binded to the kepware tags. I have this issue only for the widgets that are inside a contained mashup. For other widgets it just works fine.
